I recently bought a 6 year old, but never ridden bike. The trigger on Alivio shifter has been not engaging on some shifts. The problem was caused by 6 year old grease causing the pawl to sometimes not engage.
I was hesitant to disassemble the shifter to clean it properly because of posts warning of the complexity and difficulty getting it back together. It proved to be simple, but I only removed the downshifting mechanism, since that's what I was having problems with, and took photos to assist in reassembly.
Here's the order of what I did.
Remover the bottom cover plate. One screw
loosen 10mm nut - Left hand thread
lift "downshift" lever out of housing
Remove bushing from shift lever
Remove c clip from pawl
Remove pawl
Remove spring. Note smaller hook engages lever, larger hook engages pawl.
Clean with alcohol, then automotive paint prep. The alcohol left a waxy film. The paint prep takes film off and leaves no residue.
lubricate
reassemble
I started to disassemble the upshift mechanism as well but quickly changed my mind. I can see that it might become difficult to keep parts oriented correctly without some reference.
Remove pawl
lubricate
reassemble
