If you ask the question you should probably let the LBS install it . Ask them if you can watch and learn .
Dont you currently have a thread about whats wrong with my fork install ? You really are the last person that should be advising someone how to install a fork since you still have not installed one correctly . Your cut and paste advice is unneeded and speaks volumes of your inabilities of anything bicycle related .Again , please quit posting advice of matters of which you have very limited knowledge , you are not doing favors to the unsuspecting noobs who are not aware of your inadaquacies and very limited knowledge .Dremer03 said:I run a uncut steerer tube on my bike, you just put spacers above and below the stem. I did run into issues with not having enough spacers above, so make sure you have more than a 1/8 of a inch of spacers above the steerer tube.
You just going to be switching forks right not headsets?
If it is just your fork you just need to swap the crown race. Watch these 2 Videos
And this
Good luck:thumbsup:
We would have to know what Disc Brakes you have to advice you on adjustment after installing on to new fork.
ChillAZ.MTNS said:Dont you currently have a thread about whats wrong with my fork install ? You really are the last person that should be advising someone how to install a fork since you still have not installed one correctly . Your cut and paste advice is unneeded and speaks volumes of your inabilities of anything bicycle related .Again , please quit posting advice of matters of which you have very limited knowledge , you are not doing favors to the unsuspecting noobs who are not aware of your inadaquacies and very limited knowledge .
Yeah, just the fork and my brakes are Avid BB7s. I think I'll just have the shop do it, I do have to trust my life to this thing. >.>Dremer03 said:You just going to be switching forks right not headsets?
Good luck with your LBS then :thumbsup:Bandin said:Yeah, just the fork and my brakes are Avid BB7s. I think I'll just have the shop do it, I do have to trust my life to this thing. >.>
lol .. then how is some one supposed to learn something if they don't ask a question.AZ.MTNS said:If you ask the question you should probably let the LBS install it . Ask them if you can watch and learn .
In all fairness to the little drummer boy, he does have a statement in his sig "Post count does not represent actual MTB knowledge"AZ.MTNS said:Dont you currently have a thread about whats wrong with my fork install ? You really are the last person that should be advising someone how to install a fork since you still have not installed one correctly . Your cut and paste advice is unneeded and speaks volumes of your inabilities of anything bicycle related .Again , please quit posting advice of matters of which you have very limited knowledge , you are not doing favors to the unsuspecting noobs who are not aware of your inadaquacies and very limited knowledge .
Using it as a drift. long end almost parallel to steertube catching bottom of crown race. Gently tap with hammer around until race pops off. Causes way less damage then a flat screwdriver as there is more surface area contacting.gmcttr said:I'm not sure how you use an allen wrench to help remove the crown race. If you have trouble with it, just have the lbs pop it off.
Pay close attention to the order and orientation of the headset pieces when you remove the old fork.
I agree - get the tools yourself and do it instead of the lbs.NMPhi767 said:I have installed three different forks now. It is not a big deal if you have the right tools and some mechanical aptitude. I decided to buy the tools since I came to the conclusion long ago that I was tired of bike shops and was going to make sure that I could do all of my own maintainence. If you only are planning on doing one, I would just take it to the shop since a tube cutter and a star nut installer will cost you about 40 bucks. Sure you could just take a hacksaw to the steerer tube and use a hammer and a bolt to set the star nut, but like anything else, having the right tools makes it so much easier.
The crown race is specific to the fork. There is no swapping involved.Dremer03 said:I run a uncut steerer tube on my bike, you just put spacers above and below the stem. I did run into issues with not having enough spacers above, so make sure you have more than a 1/8 of a inch of spacers above the steerer tube.
And this
Good luck:thumbsup:
So I want to have this straight. Your telling me that this (below) cant be swapped from fork to fork. I always understood the Crown Race to be only specific to the Headset not the fork. Am I wrong?Ken in KC said:The crown race is specific to the fork. There is no swapping involved.
I'm wrong. You're correct.Dremer03 said:So I want to have this straight. Your telling me that this (below) cant be swapped from fork to fork. I always understood the Crown Race to be only specific to the Headset not the fork. Am I wrong?
no worries:thumbsup:Ken in KC said:I'm wrong. You're correct.
Not enough coffee yet, I guess.
Thank god you cleared that up - I was about to go put my chris king crownrace back on the fork that is mounted to a cane creek headset :thumbsup:Ken in KC said:I'm wrong. You're correct.
