How does Jeff Lenosky do those barspins where he spins it 360 degrees? I only ask because he has a front brake as well. Does he just have an extra long cable and twist it back when the camera isn't looking? Or what.
I believe his front brake line is routed through the steer tube of his fork. He just uses big lengths of housing for the rear.sovietspyguy said:How does Jeff Lenosky do those barspins where he spins it 360 degrees? I only ask because he has a front brake as well. Does he just have an extra long cable and twist it back when the camera isn't looking? Or what.
The brake cable/line goes through the steer tube. As for the rear, an extra long housing, or he is running a mechanical disc with a Gyro setup. I have nott seen a closeup of his bike.XSL_WiLL said:I believe his front brake line is routed through the steer tube of his fork. He just uses big lengths of housing for the rear.
Wrong.urbanfreerider666 said:nope. He runs both of his cables really long, ive seen both his bikes in person, and ive riddin his trials bike. both cables are just really long.
looks like one in the inside and the others longXSL_WiLL said:Wrong.
Yup. Guy said that he ran all his cable super long. Just thought I'd clarify.SHIVER ME TIMBERS said:looks like one in the inside and the others long
Pictures don't show up. Could be the computer at school. Don't know.FrontRanger said:These images should give you an idea. Looks like chase does the same thing. Look closely at the cable routing from the lever. Sorry these are the best closeups I have.
They work for me. I even see them in your post. Must be something blocked on your end.XSL_WiLL said:Pictures don't show up. Could be the computer at school. Don't know.
The guy uses a hollow star fangled nut and compression bolt. And runs his brake line through that.
.243 makes a nice pro looking one. thats what im running. comes with starnut, cap, and bolt. i was thinking about it and you could probally just drill a hole in the top cap then in yoru star fangled nut as well...whitebassbenny said:where can you get one of those ?
Drilling is a bad idea. Just use a BMX starnut for 1 1/8 steerers. A shop that deals with some decent BMX bikes should have a few for around 5 bucks.zerossix said:.243 makes a nice pro looking one. thats what im running. comes with starnut, cap, and bolt. i was thinking about it and you could probally just drill a hole in the top cap then in yoru star fangled nut as well...
haha dude you hate my ghetto fixes...'fixes'XSL_WiLL said:Drilling is a bad idea. Just use a BMX starnut for 1 1/8 steerers. A shop that deals with some decent BMX bikes should have a few for around 5 bucks.
Naw, I use plenty of ghetto fixes. Recently I've been using loose change a lot. Don't ask what for.zerossix said:haha dude you hate my ghetto fixes...'fixes'
