1 - 2 of 2 Posts
I need a 12mm hub and all I have is an old Outlaw with blown out bearings. So I need to replace them.
I briefly tried a socket and hammer with not luck.... so If any of you know how to get them out, post up.
-Mark
Meh.
Best solution is to bring it to your shop. You can fab up a little bearing remover, but since the bearings are trashed anyways, you can really just jam the end of an allen key against the bearing race and give it a couple good taps.
It's pressing it in that you need to be careful with. I would use a bearing press. Or a threaded axle, a couple washers, and some nuts. Make sure those new bearings go in nice and square.
1 - 2 of 2 Posts
