1 - 6 of 6 Posts
i've got a steel 29er geared frame that i only intend to ride as an ss w/ a white industry eno hub. i want to ditch the cable stops. i'm thinking about repainting anyway so i don't care about damaging the existing paint. i just don't want to damage the frame. so what do i do? use a propane torch or something like that?
thanks,
head
btw it's a vicious frame.
I've never done it, nor have I ever even thought about doing it, but I'd probably just grind them off if I had any desire to remove cable stops.
You might try posting this in the frame builders or singlespeed forums here too.
Cable stops are small, you could dremel them off easily, then use an 80 grit dremel paddle sander to finish off the last bit... Absolutely no torch!
I have been building a cafe racer out of a 1977 honda cb550f, The dremel has been a godsend for grinding and polishing... One of my favorite tools.
...idios...
I just Dremel'd the edges of the stops on my Orange and filed out the closed end enough to allow a hose/cable to sit flush. A quick filing cleaned everything up. Then I drilled a hole under the stop, but above the frame, so as to allow a cable tie to be used to secure; although this turned out to be unnecessary as the edges of the stop held the hoses in place.
1 - 6 of 6 Posts
