Think about it. Those plastic coated brake/gear cables that rub against your frame can eat a hole right through it.Merkyworks said:dude I have a "loose" zip tie on everyone of my forks. its the easiest way to see the max travel the fork has used on a trail or jump. and as for scratching the stans. well are you telling me that plastic is harder than alum. or steal? I dont think so, it might wear the anodizing but then the seals do that to so big deal. or even better if i could get a fork to last that long to acutally see wear that would be nice.
just put one on the stan. as said and let all the air out of the fork (if you can) and the fully compress it. then measure from the dust/dirt seal to the bottom of the zip tie. very easy and accurate
It has more to due with the distance between the crown race and axel when uncompressed. The actual "part that goes in" will be a little different for every 80mm fork out there but the distance from crown race to axel will be the same for all 80mm forks.Markleo said:I meabt how the manufacturer sais this fork is 100mm or 80mm etc. Is it the measurment of the plush part (the part that "goes in") on the fork? Thanks.
You are not correct.BraveHeart said:It has more to due with the distance between the crown race and axel when uncompressed. The actual "part that goes in" will be a little different for every 80mm fork out there but the distance from crown race to axel will be the same for all 80mm forks.
This is how and why the frame manufacturers are able to design a frame for a specified XXmm travel fork. What they are really saying is that the bike is designed for a fork with a particular overall length. If you deviate from that recommended length, the handling of the bike will be affected.
If that were true than frame manufacturers would have to suggest a crown to axle spec to match a fork to their frame, which they do not. Only the travel. Its a lot more than a general recommendation, it has to do how the bike sits in the neutral postition.snaky69 said:You are not correct.
Many forks with the same amount of travel have different axle to crown heights due to the crowns, exposed stanchion, drop-out configuration and all. The 80mm is nothing more than a general recommendation to make sure the bike handles like it's meant to. 80mm of travel means exactly that, when fully compressed, the fork will have traveled 80mm. Which means the exposed part of the stanchion will be 80mm shorter and the fork will have an 80mm shorter axle to crown height etc.
A 100mm Manitou gold label has a 475mm axle to crown height. A rock shox pike at 100mm will have a 470mm axle to crown height, a marzocchi dirt jumper('06 and later) at 100mm will have a 486mm axle to crown height, a rock shox argyle at 100mm will have a 491mm axle to crown height(a difference of 21mm or almost an inch, that is almost 1 degree in head angle difference compared to a gold label). I used dirt jumping forks as an example as those are the forks I know best, but this goes for any and all forks.BraveHeart said:If that were true than frame manufacturers would have to suggest a crown to axle spec to match a fork to their frame, which they do not. Only the travel. Its a lot more than a general recommendation, it has to do how the bike sits in the neutral postition.
If you put a 100mm fork on a bike spec'd for 80mm, you are raising the front of the bike which will slow steering and cause wheelies on climbs. The same would happen if different manufacturers used different crown to axel lengths for an 80mm fork.
Not harsh at all snaky69. I can't dispute your numbers since manufacturers don't seem to publish them. Plus or Minus 15-20 seems a little steep though, and people would complain as they did in the case of the 888, and rightly so. What you are effectively saying is that there are some 80mm forks that are taller than some 100mm forks on the market, I can't honestly say that I would buy that.snaky69 said:A 100mm Manitou gold label has a 475mm axle to crown height. A rock shox pike at 100mm will have a 470mm axle to crown height, a marzocchi dirt jumper('06 and later) at 100mm will have a 486mm axle to crown height, a rock shox argyle at 100mm will have a 491mm axle to crown height(a difference of 21mm or almost an inch, that is almost 1 degree in head angle difference compared to a gold label). I used dirt jumping forks as an example as those are the forks I know best, but this goes for any and all forks.
As you can see, no fork with the same amount of travel has the same axle to crown height unless it comes from the same manufacturer, get your facts straight. Frame manufacturers design a frame according to a certain axle to crown height, and usually a bike using a fork within plus or minus 15-20mm of that will handle the same way it should. Also, usually, the manufacturers assume that most forks in the same travel as the fork they designed the bike around have approximately the same axle-to-crown height.
The '04 and '05 marzocchi 888's we're insanely tall and choppered out bikes and made them handle like pigs, and people complained that they were the tallest 200mm fork out there. Marzocchi redesigned their crowns so that the axle to crown height was nearly 25mm shorter, and guess what, they are still at 8 inches of travel(200mm).
I'm not trying to bash on you but to make you better informed, I hope I didn't come off as harsh.
I own a dirt jumper and will soon own a Slammed Nemesis Project Z1. I have some time on a pike, the other forks I have mostly seen or parking lot tested but no more.BraveHeart said:Not harsh at all snaky69. I can't dispute your numbers since manufacturers don't seem to publish them. Plus or Minus 15-20 seems a little steep though, and people would complain as they did in the case of the 888, and rightly so. What you are effectively saying is that there are some 80mm forks that are taller than some 100mm forks on the market, I can't honestly say that I would buy that.
On another note, of all the forks you mentioned, which I assume you own, do they really travel 100mm or is there some variation there also?
