1 - 8 of 8 Posts
thebikedoctor33 said:
can sumone explain thru axles for me. can any wheel be used with a thru axle fork?
Simply put there are QR axles and solid axles. Usually a 20mm front thru axle and a 10 / 12mm solid rear axle. To use a 20mm set-up you need a 20mm hub and fork. The rear can use a solid axle depending on the dropout size.
Cynical Bystander
The front can use a solid axle as long as you get the right one for it. It's going to be a 9mm I believe. I think some have 10 but I'm not really sure..... If you do that it'll fit into any QR fork.
just to clarify, a solid axle and thru axle isnt the same thing. A thru axle is removable from the hub and slides through the fork dropouts. A solid axle simple has bolts at both ends instead of a qr.
Cynical Bystander
Good point, guess I just wasnt paying attention, lol.
Cynical Bystander
zedro did you have anything to do with taking off about 20 posts from me?
i'm cleaning this mess known as the downhill board up. If a thread is deleted, any posts within that are gone with the associated post count.
Cynical Bystander
Props to you for taking on such a burdening odyssey.
1 - 8 of 8 Posts
