Bull_D said:
just finishing my first "solo" wheel build......had some supervision on my first two sets. question for the pro's here.....how close can you expect to get your tension readings (using something like a park tension meter)? i assume a narrow range? unlikely to be exact on all spokes? some i know just use the "by hand" method, wondered if anyone accurately measures.
I normally get them all to the same tension by plucking the spokes and this is very accurate. I may then put a tensiometer on just one or two spokes to test the actual tension. As an example I've just measured the spokes in the tight side of a rear and the tension range was 1250N to 1300N. Not sure on the math to work out what % this is.
There are other factors, you are attempting to get the rim true and round and with equal tension and obtaining this is sometimes not possible. My rim (above) was a DT 4.2D which is accurately made and I achieved true (lateral and round) and acceptable equal tension. Sometimes this is not possible and if the rim is not that well made you have to compromise and in this situation I favour equal tension but his might not be possible if the is rim being a PITA (yes some are).
Now here's another exaple for you. I've just had the opportunity to evaluate a brand new wheel built by one of the mailorder builders (UK), people are always raving about their wheels so I thought I'd take a closer look (Mavic 717 a well made rim). The wheel was laterally true but was not too round and the spoke tensions were all over the place yet people seem happy with their builds. The spokes were all wound up too. Whether they stay true is another matter but folks buy them and recommend them so I assume they work.
Roger
Edit for spelling mistake.
