During the past weeks I have converted a good number of wheels (for friends , wife’s bike etc) using the DIY method of strapping tape and recycled valves from old tubes. Besides the notorious hassle of sealing the Supersonic tires (pinholes) , I have found that narrow, 1.9 mud tires are also very diffucult to inflate using the standard method.
The couple of tricks below can facilitate airing up difficult tires – just thought that others might be interested..
How to seal Pinholes: Instead of spending hours shaking, reinflating and refilling tires hoping that sooner or later all the pinholes will seal, just get a brush and some undiluted latex. Degrease the innner casing with soap, and paint it with a thin layer of liquid latex, focusing on the sidewall where the majority of the pinholes are locates. It’s a 3 minutes job.
Let it dry for a couple of hours, mount tire, fill with Stans/homebrewn solution and inflate.
How to bead difficult/narrow tires: before mounting the tire, throughly cover with latex the tire bead at the rim interface. Mount the tire with an inner tube and let the latex cure overnight. The following day, unseat a small portion of one bead (i.e. left side)and carefully remove the tube. If you have a surgeon’s hand, 60% of the left side and 100% of the opposite bead will stay in place, glued to the rim by the cured latex. This trick works wonder if you use the DIY or Eclipse method. You cannot fit a tube if you have the Stans rimstrip/valve in place. In that case you can simply fill the tube leaving a small section of bead “unbeaded” and leave the valve stick out of the sidewall (just don’t pump it to 50 psi!!)
Hope this make sense –
Now use this thread to share >Your< top secret tips!!
fab
fab
