penske1 said:
I was experiencing exactly the same knocking noise on my 575. It was driving me nuts. It was highly intermittant (or so it seemed) and I would've sworn it was coming from the rear shock. However, I noticed on a ride this weekend when I shifted from my middle ring to the big ring the knocking stopped. As it turns out, the knocking only occured when the rear derailleur was in the smallest three cogs, especially when in the middle chainring (least chain tension.)
So, upon further investigation, I noticed the rear derailleur jockey wheel cage would slap the chainstay when in the smaller cogs, especially on washboards and stutter bumps. I added a little tension to the pivot spring screw on the rear derailleur pivot. It helped, but I think I still might need to put some sort of cushion on the chainstay where the derailleur hits.
By the way, I'm running an XT rear derailleur (NON rapid rise.) This may just what I needed to make the switch to SRAM. Definitely not a fan of dual control/low normal!
Anyone else seeing this?
My noise is still there but not as much now. I honestly think it is the RP3 shock itself. Anyway here is what I did to try and correct the problem so far.
1. Replaced both DU bushings
2. Replaced the two aluminum reducer bushings at the to of the shock
3. Replaced the chain
4. Installed new pedals
5. Removed and cleaned/ lubed the crank and bottom bracket( XT )
6. Removed cassette...cleaned and lubed
7. lubed seat post, seat rails
8. Lubed headset, top cap
9. cables adjusted, etc.
Man, you get the picture, I left nothing undone except replacing the cartridge bearings.
The only thing I can think off is I removed the large chain ring to install a RaceFace bash ring but, everything is tight. Like I said it has quieted down a bit but, I still can notice the knocking sound.
Any thoughts?
