I'm building up my first 29'er. I had planned to go with Martas, but have since done an about-face, and am looking more carefully at the new Hope options. I'm posting today to ask for some input on which option would be the best for what I'm looking for.
I weigh 82 kg, or 180 lbs, and ride cross-country trails. The bike will be a fully-rigid single speed in the fall and winter and a geared, suspension bike in the spring and summer. I'd like to use Paul's Thumbies on it.
Here are the options I'm kicking around:
- X2 183/160 (geared), 160/160 (rigid - the fork won't accept a rotor larger than 160 mm) with braided housing and floating discs
- X2 180/160 (geared), 160/160 (rigid) with braided housing and Scrub rotors - so long as there are no compatibility issues with the Scrub 180 mm rotors and the Hope 183 calipers)
- V2 with braided housing and floating discs
- Mini X2 Pro with braided housing and floating discs
- Mini X2 Pro with braided housing and Scrub rotors
I'm happy to consider other options, but I'm pretty confident now that the Hope systems are what I'm looking for. I've scanned (and scanned and scanned...) this and other forums for information, and, as many of you know better than I do, there is no shortage of options and opinions on these matters. Also, as some have recommended, I'm happy to consider using a non-uniform system on the bike (i.e. one model for the front brake and another for the rear).
Thanks. I appreciate the help.
