I have a set of Tech V2s with the floating 203/183 combo with the stock Hope organic pads. I also have a set of Tech M4s with floating rotors and Hope organic pads.
On my M4s, with the bike in the stand,when I pull the levers, they are solid, they come to a complete stop. I can pull the lever with all my strenght and get them to move closer to the bar, but overall, a nice solid feeling.
With the V2s, I am getting a more mushy feeling. I have bleed both the front and rear (also bled the M4s), using the same technique shown on the Hope website, using the same Valvoline DOT4 fluid. My calipers were centered using feeler guages, and the pads are contacting the rotors identically (no flexing in the rotor).
When on the bike, it is not noticable, the brakes are STRONG, infact I have the BPC dialed almost all of the way out (same with the M4s). I have noticed, if I drop in a set of Sintered pads, the levers have a much more positive, stiff feeling to them.
So, my question is this, are the M4s feeling more solid in the stand because they have a larger contact with smaller pistons, so the lever cannot compress as easily? Is it possible that the V2 pistons are strong enough to "compress" the pad material of the organics?
Or, do I need to bleed them again? I have pushed about 30cc of fluid through each brake, the fluid is clean, no air bubbles, and the front and rear V2s feel the exact same after bleeding. I really don't think this is the problem, since both front and rear feel exactly the same.
