dopaminer said:
Dropadrop, are you certain about those weights?
Hard to be certain when I never held a V2 (or Tech M4) in my hand. These values are directly from the spreadsheet Hope sent me:
Tech V2:
Includes Tech lever, post caliper, adaptor, braided hose, 203 floating rotor
514g (above with vented rotor 629g)
Tech M4:
Includes Tech lever, post caliper, adaptor, std. hose & small rotor (160 or 183mm)
466g
I am assuming the M4 has been weighed with the 183mm rotor as otherwise that does not make sence...
There is also weights for rotors:
Floating Rotor - 183 - 146g
Floating V2 Rotor - 183 - 180g
Floating V2 Rotor - 203 - 208g
Which means the V2 set with a 183mm rotor should weigh 486g vs. 466g for the M4. As far as I can understand this also means the V2 set without the rotor is lighter (not useful information though, as you will anyway be running the heavier rotor with the V2).
Now my confusion came from the fact that the document states the braided hose will ad 90g to the weight of the front brake. I asked Hope for clarification, and they said that indeed, the V2 will weigh less then the M4 if you take a M4 with braided hose. Personally I found the 90g to be quite a lot, but you just need 20g added weight from the hose to already be at an equal weight (V2 comes with braided hose as standard).
The document also lists separate weights for Lever, braided hose & caliper. Under V2 the weight is 310g. M4 is listed with standard hose at 274g which does not quite fit in with the previous measurements (unless there is a difference with adapters which I don't believe). However if the braided hose where really to add 90g to the weight the V2 would still be lighter.
But I'm not convinced the braided hose adds so much weight. Sicklines has a measurement of Tech M4's at
278g which is pretty spot on with Hopes claimed weight. I have submitted weights of my previous Mono M4's (with braided hoses) to sicklines and they where
287g. Is the tech lever lighter or heavier? How about the new caliper? Hard to see how you could come up with a 90g increase for the braided hose...
Any more clear? Not for me, but at least this should help you try to make more assumptions like me.
edit: seems the tech lever is 21g heavier then the previous one, so that already puts the braided hose weight difference to 30g. Anyone know if the new caliper is heavier or lighter?
edit2: according to Hopes own pages the Mono M4 with standard hose is 36g lighter then the Tech M4, so that would mean the braided hose adds about 45g. Anyway, I believe that if you take the M4 with braided hose you will be really close to the V2 weight.
