I've got
1) Marzocchi Shiver SC with the 20 mm thru-axle set-up
2) 185 mm Avid mechanical disc brake calipers both front and rear
3) The front hub is a HOPE Big 'Un that only accepts a 5 bolt rotor, which I ordered from HOPE as well.
I matched the diameters of the Avid rotor with the HOPE rotor and they are identical. The HOPE rotor is barely thicker in gauge and, it has a larger brake track width.
I cannot fit this front wheel into my Avid caliper set up. Any Suggestions?
