1 - 2 of 2 Posts
Hi.
HAs anyone had troubles converting the rear hum from a quick release to 12mm bolt through? I have got the hub sorted, but putting in the final part its as if something is missin? Can anyone tell me exactly what comes in the kit.
Cheers
How did it start?
Did the hub start out as a quick release? Because if it did I am almost possitive that you can't convert it to a thru axle. But if it started out as a thru axle and you want it to convert it to a quick release there is a kit but I don't have any exprience putting it on.
1 - 2 of 2 Posts
