I'm sure this has been covered before, but when I search, I get conflicting info. I want to change my hope pro II hubs to 9mm using the DT Swiss RWS skewer. What end caps do I need? Do I use the thru bolt version or the QR version?
If you want to use a front 9mm through bolt RWS you need this: http://www.chainreactioncycles.com/Models.aspx?ModelID=40654elarkin42 said:I'm sure this has been covered before, but when I search, I get conflicting info. I want to change my hope pro II hubs to 9mm using the DT Swiss RWS skewer. What end caps do I need? Do I use the thru bolt version or the QR version?
