Thanks - my french isn't so good so I can't really do any searching so do you know of any online shops in France who are selling these rotors? Maybe even a price?!20.100 FR said:They are available from hope france.
I haven't heard of problems yet.
They do look nice, but they aren't floating. It is just a cool way of attatching the alloy carrier ot the disk...emkay said:at Chainreactioincycles.com - looking really nice and I think I will give it a try!
My fault - I just once received an email from Chainreactioncycles and they called them floating rotors so I just continued calling them floating thinking that attatching a steel surface to a alu-spider was called floatingbike_freak said:They do look nice, but they aren't floating. It is just a cool way of attatching the alloy carrier ot the disk...
Are the pictures on this thread 160 and 180 mm or 140 and 160?emkay said:They are here: http://www.chainreactioncycles.com/Models.aspx?ModelID=3487
The rotors are called "6-bolt floating disc" despite not being it ;-) They are available in 140,160 or 180 mm!
140 and 160 if I recall correctly from the original post.Weenie said:Are the pictures on this thread 160 and 180 mm or 140 and 160?
They don't make them in 185mm, but i've got a 180mm in that style on the rear of my bike.STS said:Also Hope Mono Ti 6-Pot uses this kind of rotors
But do you know if only for the 225mm or also the 185mm?
No sir. The ones pictured above (which are mine) are 140/160 mm. They're also the lightweight rotors which you can tell by the carrier design. AND they float.leichtreiter said:so the rotors in 140/160/180 mm are the new lightweight floating rotors and actually don't float (sideways) whereas the real floating ones are xx5mm (eg 185mm) in outer diameter, yes?
