1 - 3 of 3 Posts
· ...idios...
"...does that mean I need a new caliper?"
You have a set? The front is 160mm IS also? If that is the deal with the front, then you could switch the front caliper to the rear on a 140mm rotor and put the rear caliper on the front with a +20mm adaptor and a 160mm rotor. Robert, as "they" say, would be your uncle.
1 - 3 of 3 Posts
