1 - 8 of 8 Posts
Hello,
I have giant glory DH with Hope Pro 2 rear hub 150X12.
I disassembled my wheels after the ride and the rear wheel fell down accidentally.
A part of the hub came apart - the cassettes with the ratchets part (the cassettes are still tightened on the ratchets part).
I put it together and now i can easilly disassemble this part from the hub.
Is this a problem? is it suposed to be tightened on the hub?
You should be able to pull it apart by hand.
This is one of the things I love about hope. No tools needed. Just break down by hand to rebuild it all over again.
= dirt torpedo =
the Hope Pro 2 freehub just slides onto the spindle, with the hard plastic seal ring that will snap into the hub body, nothing else really holding it together.
just make sure the seal is snapped in and seated all the way, and you're good.
Discussion Starter · #5 ·
something wrong?
I cleaned the old grease and put some new and after I put the hub together the ratchet doesn't work well:
When I stop pedal the pedals keep moving slowly with the wheel. Of course with very minimally power, just on working position, I don't feel that while riding.
What is the problem?
1 - 8 of 8 Posts
