Drakken_11 said:
Oh, so does that mean that companies other Shimano have attached the Rear D to the axle??
And from your last sentance; am I to understand that you need a special frame for the Thru-axle setup??
Shimano gave up on the concept of fitting the rear derailleur to the axle. Other companies never adopted the concept in the first place.
Yes, you might need a specific frame for the Hone. The derailleur needs a grove under the axle to hook into. The hook in the grove prevents the derailleur from rotating. Think of it this way: Threading into the axle allows the derailleur to rotate around the axle. The nose sitting in that grove prevents that. Now, the nose might hook into the drop outs, if the drop outs are deep enough. You might be able to hook the derailleur into your hanger - but I've never tried that either.
http://techdocs.shimano.com/media/t.../RD/EV-RD-M601-2603_v1_m56577569830609151.pdf
shows a Hone. You can see the nose on the version for the BMX (horizontal) drop outs. Part 3. Not sure where the nose is for the standard drop out. The table claims it would be the same part as for a Saint (MD800). If this is the case: The nose it right under the axle.
Your frame should be able to accept a 10mm axle if you run a QR setup now. So if you want to try the Hone you'd need:
- rear wheel with a 10mm x 135mm through axle hub
- a 10mm through axle
Let me know if you try it - and if it works. I personally would shop a bit for a Deore or LX derailleur. Less hassle and probably same cost (consider the additional cost for axle and hub/wheel).
