Very clean....nice work.
B
B
Check out that first thread from a couple months ago, lots of good advice suggestions, but none of them that are available are simple and cheap.bigdrunk said:None of the current offerings fit the Leviathan?
I was lucky to get that e-type bracket for $2 bucks from the LBS (it was actually the whole derailleur for that price, a very ancient FD that isn't made anymore), and that piece of metal from the window blinds, I only had one. Besides that, I don't really know if its bulletproof yet, no long term testing has been done. As for turning during a wheelie, its MUCH harder on a 29er.Cloxxki said:Can you do a couple more of those? ... Need to learn to take corners during the wheelie.
Good point, but would a FD keep the chain from dropping to the outside? I'm not sure. As for weight, the thing I made weighs about 65 grams and I think the Spot Brand chainguide weighs about 80 grams (=145 grams total). The SRAM XGen FD that those replaced weighs about 180 grams. So the weight is a little better, and add to that the fact that I didn't want to mess with the FD, because I'll probably end up using it again in the future.wooglin said:Looks good. But I sometimes wonder at the weight of the jumpstop + the bash guard/outer ring vs a front derailleur with the lower limit screw cranked way in. And how much of the derailleur could be cut away.
