Holowgram cracked crank Cannondale scalpel
1596 Views 5 Replies 4 Participants Last post by  Eno Esool
Hello everyone, thank you for accepting me, I am writing to you from Spain I have the following problem with the crank of a Cannondale scalpel 2 from 2021, it is the second one that cracks me and in both cases it has been accepted as guarantee, this one with more than one month of delay, any case of a colleague that has happened, or guide me what the cause may be, greetings.
1 - 6 of 6 Posts
if the crank cracked twice, I would nicely ask for a different crank this time. A crank defect can cause a wreck/injury.
If that happened twice I'd be looking at the spindle. It also looks odd that the crank bolt isn't flush.
Light Fluid Liquid Camera accessory Material property
[QUOTE = "bcriverjunky, publicación: 15450376, miembro: 773902"]
Si eso sucediera dos veces, estaría mirando el eje. También parece extraño que el perno de la manivela no esté a
Si eso sucediera dos veces, estaría mirando el eje. También parece extraño que el perno de la manivela no esté al ras. View attachment 1952758
[/CITA]
Esta es la imagen de la segunda manivela,es curioso el caso en garantía no ponen inconvenientes pero no se da una alternativa a otra y no hay en producción hasta el 15/11.
Replace the spindle.
Get use to them cracking unless you go with a different crank set.
Automotive tire Blue Bicycle part Rim Carbon
Crankset Bicycle tire Bicycle wheel Automotive tire Automotive lighting
Automotive tire Tire Irrigation sprinkler Bicycle part Tread
This was my 3rd set. At some point Cannondale will stop warranting them for you.
1 - 6 of 6 Posts
