I've been thinking this one over a bit. It would be a cool mod to put a coil into the right leg of the 66SL. Anyone know if the leg and damper assmbly are the same as the right leg of the RC2x? If so, then it should be no more than dropping a spacer and a spring in there right?
It seems like I could do a lot more with modifying spring curves if I had a option of one coil. I could still use the negative air pressure to lower the fork, which is the main reason I bought it to begin with. I would also have the extra backup reliability of a coil, which wouldn't hurt.
Anyone know how much those springs weigh?
