1 - 3 of 3 Posts
Its a no go. The threaded sleeve you mount the rockers to at the top of the shock is designed to be press fit into Fox DU bushings. The CCDB ones are a larger diameter than the Fox. If you got a larger diameter sleeve made, or found some CCDB bushings with a smaller I.D., you would be in business.
Buzz
1 - 3 of 3 Posts
