Just a tip for anyone new who is buying a used bike, or if you've had it for a while. My friends front disc brake kept falling out of adjustment and rubbing.. And while the brake was gripped, if you pushed on the bike forward the axle would move in the fork. So I thought the cone nut was loose but I looked closer and it was sliding in the dropout. So I cleaned it with alcohol and cleaned the inside of the dropouts and the lock nut on the axle with a wire wheel on my dremel and now its perfect. There was a lot of grease and junk on both parts and the lock nut wasn't gripping the dropout no matter how tight it was.
Sent from my SPH-L710 using Tapatalk 2
