how much sag front and rear???
A couple of things that might help is to post your weight, fork type and rear shock type. '08 uses a different shock than the '07.sponge_man69 said:how much sag front and rear???
check - I had 18 clicks on the floodgate (granted, it was a 2006 model IIRC). Checking my setup log, I ran 6 clicks (of course, different bike too).slocaus said:Interesting. I usually only run about two clicks of platform / floodgate. Long steady fire road climbs I will go up to four.
I will try it. I will check sag with the new fork. I ran the same sag front and rear with the 100mm fork, but with the 120mm, I suspect that I will run more sag front than rear.GreenLightGo said:check - I had 18 clicks on the floodgate (granted, it was a 2006 model IIRC). Checking my setup log, I ran 6 clicks (of course, different bike too).
FWIW - I really liked the MC3.3. My PUSH'ed RP23 is outstanding (aside from the harmonic squeak you get when running ProPedal = but that is not a PUSH issue, just an RP23 characteristic).
