Hi all. Apologies if this had been asked before but I'm pressed for time.
I bought a used 2016 fox 34 factory 27.5 fit4 and I can't seem to get it set up to my liking.
For reference i ride mainly trails with rocks and many roots on the east coast. I want a good plush beginning stroke that doesn't dive under braking or bottom out easily.
The bike is a Cannondale Prophet that I'm converting to 27.5. I just need tires and that's done.
I'm admittedly a n00b with high end forks so I may be just doing it wrong. Also I have no idea when or even if it was last serviced so that might be it too. I'm 155lbs with gear.
Pressure recommendations, compression and rebound advice? Help a bro out if you all so kindly would! Thanks!
