Hello everybody!
I have found a lot of useful information in this thread, and it gave me a general idea what I should look for for a start point for my tune trip, but still want to hear some suggestion for my case.
I have two bikes - Santa Cruz Nomad v4 with 230x60 shock and 170 travel (leverage ratio ~ 2.83) which I think is more to the progressive side, and other bike is Canyon Spectral:ON with 230x60 shock and 150mm travel (leverage ratio ~ 2.5) which is more linear comparing to SC Nomad.
In the pictures below are the shimstack, of the two shock that I own, both of the purchased second hand as upgrade for both bikes.
And here is the questions that I have and hope somebody will help.
EDIT: I'm 75kg with equipment and 175 cm if does matter
1. I'm thinking of shock with LNL1 tune and HotDog piston (bigger compression flow valves) will more suitable for Canyon with 150mm rear travel. What is your consideration, should I change some shims or it will be a good start point?
2. As I red in other thread, MM320 tune is way over damped, but it is the suggested tune from SantaCruz for nomad, should I look for something more linear in point of rebound, or better leave it like is this?
3. Any suggestion for custom shim stack with available shims will be highly appreciated, as in my country there is limited access to shims and stock kits from RockShox.
Thanks in advance!
Thanks in advance!
