My mis-spent years as a weight weenie has finally turned around and bit me. An aluminium bottle cage bolt is stuck on my frame, with the tiny 3mm allen head rounded out. I sawed a groove on the bolt head and tried to remove it with a screwdriver but it still won't budge.
My next move would be to drill the head of the bolt out, remove the bottle cage and attempt to remove the remainder of the bolt with a vice-grip. But before I do this, I thought I'd check here if there is any other suggestion for removing the bolt.
Specifically, is there a tool that works like reverse-threaded bit that I can screw into the stuck bolt?
Thanks in advance for all replies.
