If any one can help with this one would much appreciate?.My sram X9 Front deraillers trigger shifter is only 2 months old(mated with shimano xt front derailleur)Anyway working perfectly for the last 2 months until the last ride when the gear indicator on the front derailler trigger shifter went slightly out of alignment(instead of on gear 2 it aligned half way between 1 and 2 and instead of gear 3 it would sit between 2 and 3?The front derailleur worked fine changing gears just the gear indicator didn't line up?Now the gear indicator is stuck on gear 1 and won't move while it changes gears normally at the front derailler down below.Is this problem easy to fix and how do you fix it or will i have to send it back under warranty?Any one else have this problem?
