Thanks so much, it worked for the most part. On the front wheel it still rubs just a little bit, anything further that I can do to more finely tue it? Thanks again, big help, directions didn't come with them.xjbebop said:Loosen the two 5mm bolts holding the caliper to the mounting bracket just enough to let the caliper move. Apply the brake (squeeze the lever). This centers the caliper to the disc. Tighten the bolts while squeezing the lever. Let go of the brake, make sure the bolts are torqued and spin the wheel. You should be good to go.
