Noleen Mega Air?
I have a 2005 Fox Float 100 RLT, a 2002 Noleen Mega Air, and a 2002 Marzocchi Marathon S (air, not coil like the newer S versions).
The Noleen is ~6 ounces (~175 grams) lighter than the Fox and is very nearly as stiff but uses a very simple all air damping system. This makes it very easy to work on, but also prone to being sticky if you don't grease it often or if you use high air pressures. It also dives more than the Fox or Marathon when braking. The Noleen's aren't easy to find these days though.
The Marathon is ~4 ounces (~100 grams) lighter than the Fox, but doesn't track as well as either the Fox or the Noleen. It also seems to have issues with dropouts cracking and internal leaks that drastically affect performance. When it's working, the damping is on par with the Fox.
The Fox is the most supple of the bunch, the damping seems to work best overall, but it is also the most expensive. I am currently having trouble getting full travel out of mine though. The 3" of travel that is there is very nice however.
All these forks are noodles compared to Maverick American's DUC32. The DUC32 is very nice and is light enough, but it's damping, tall height, and lack of longer stem options makes it not race worthy in my opinion. It also requires a special hub. This is not a bad thing in my opinion because it offers such a huge leap in stiffness, but is an extra expense and headache (have to build a new wheel). The SC32 could be a real winner if it has better damping. Too bad it is heavier than the Fox though, because it doesn't seem like it should have to be.
For a mostly racing application, especially something like a light hardtail, I would choose the Noleen at this point. In fact, that's exactly what I plan to do for my next build (light hardtail with Noleen mostly for racing everything but the roughest courses).
