I'm here to save the day! :thumbsup:Assemblur said:
You need this tool in order to remove the ring nut. Then the bearing comes out. BUT, you may not need to remove the bearing(s) if you get the correct kit. The tool is shown on page 25 of the 240s manual.
I'm having a hard time getting my head around a 130mm x 12mm TA rear hub though. I don't see it in the manual, you might need a new axle and a pair of bearings. The tool will help with that if you do need to replace the bearings and axle.
