So I’m going to try and explain this without pictures, so here goes. I’ve got a old mtb from the early 80’s that I’m converting to a SS. This is the second early 80’s bike I’ve done. The first has vertical dropouts, this one has nearly horizontal dropouts. The first bike uses a DMR chain tensioner so I bought another for the second bike.
I can’t see how the tensioner will work. The angle of dropouts puts the tensioner wheel right up against the chain stay and even then I can’t get the bolts in place. So what I did was forget about the tensioner and I cut the chain so it was tight enough in the center of the horizontal dropouts. Then clamped the quick release tight.
I’m not liking this.
A- because how do you know your wheel is straight
B- given the amount of torque needed to SS I am thinking the qr won’t hold.
So now I’m thinking of replacing the qr axle with a solid one and using axle nuts. I saw this same scenario used on a utube video when a fellow converted a road bike to ss.
This bike is for my nephew to use while at university for 4 years. He’s new to biking so I thought this would be the easiest bike for him to maintain. He’s very mechanically inclinded and has been helping me with the build and understands what we are doing. I just want to build him a safe bike.
Any input regarding the tensioner or use of a solid axle is much appreciated.
Cheers
Dan
Cheers
Dan
