You need an Avid Bleed Kit or something similar, its easy to bleed it once you have the kit
FYI-make sure you clean up all the brake fluid, it eats paint. Also, if you got it on the brake pads, you'll be needing to pick up a set as well (or you can cook them-search this forum to find out how).
