1 - 5 of 5 Posts
i've got some old skook xt755 4 pots. i need to trim the steel braided hose. do i use a dremel tool? should I trim at the resevoir or the caliper end?
thx in advance
i cut my goodridge hoses with my cable cutters, not a perfect cut, but nice enough to get the job done.
a toothpick or similar down the hose during the cut helps minimize crushing.
movemint: if you manage to cut a braided hose with a razor, be sure to film it, I'd love to see it done.
Banned
The best way, which has been illustrated by myself and steve UK is to first wrap the ends of the hose with electrical tape. 4 layers should be enough, depending on how tough the hose is (more for tougher hose). After this, simply cut with a dremel and it will go right through, leaving a clean, unfrayed end, which is essential to hold in place properly. Although I have not tried it, you can likely use the conventional method of the blade or cutter, though I won't endorse it because the corners of the folds tend to deform the braiding.
1 - 5 of 5 Posts
