1 - 14 of 14 Posts
· Registered
Need a little help here! I've got a platform pedal stuck on the left crank arm. I've gone through 2 pedal wrenches, 2 crescent wrenches, and 2 allen wrenches trying to get it off. I've tried pliers, a plumbers wrench, and even tried drilling it out from the back. No luck. I'm turning the correct way to loosen but the darn thing won't budge! It's a new XT crankset so I'm worried about trashing the arm.
ANY SUGGESTIONS BEFORE I TAKE IT IN TO THE SHOP AND LET THEM WORRY ABOUT IT? :confused:
· Registered
The left pedal uses reverse threading. Are you turning lefty-loosey? If so, you are tightening it.
· Registered
Discussion Starter · #3 ·
Yep
Righty-loosey... or was it lefty-tighty. Either way, I'm unscrewing the correct direction for the left crankarm. Thanks though.
· Do It Yourself
The Park Pro Wrench is the best I've found. You can get some serious torque on it because the wrench flats have two different angles, not just 90 deg. like the standard wrench. If you don't want to buy one, take it to the shop.
· We want... a shrubbery!
I have definitely happened to me... I wanted to put platforms on for this one ride, and well, I couldn't get the pedal off. Got pretty pissed, took off the crankarm, hooked it up to a vise grip (I was really pissed by this poing :p lol) and used a series of wrenches with a cheater bar--and yea, I was unscrewing it the right way... Never did get it out because someone has stolen my bike since (sigh, if anyone sees a Black/Red/White Stumpjumper FSR XC Pro with the rear shock installed upside down, please send me a message!)... guess it's their problem now.
· Registered
Discussion Starter · #6 ·
Yep
Picked up the Park Pro pedal wrench yesterday and it didn't last 5 minutes. The metal bent and mushroomed against the awesome strength of a $10 pedal. I'm going to take the crankarm off and take it to a good shop in town. Thanks!
· Probably drunk right now
Are you sure....
At the risk of offending you, are you sure you're turning the wrench the correct way? It seems like a stretch to me that you would bend and mushroom a pedal wrench yet the aluminium threads holding your pedal on the crank didn't strip out. The process you've gone through seems to defy physics.
Ken
· rack admirer
heat
I put a propane torch to the spindle end after I put locktite on the treads. That was in 2001. the crank arm is still fine. A little bit at a time. Don't try to melt it.
Yoe are pulling towards the REAR of the bike, right?
· Registered
don't waste time on it
You shouldn't waste time on this pedal. The best solution is to take to the shop and let them deal with it. You spent alot of hours and labor. It is better to have a different person to solve the problem .
· Registered
Discussion Starter · #14 ·
Success!
Well, I took my own good advice. I gave up!
Took the crank into a quality bikeshop here in Boulder, Vecchio's, and they had the pedal off in less than 5 minutes. They had no luck with the Park Pro pedal wrench but quicly moved to locking the pedal in a vice and voila! PEDAL IS OFF! Thanks to the wrench at Vecchios and everyone for their advice. Now if I can just avoid cross-threading the new pedals...
TIME TO RIDE!! :)
1 - 14 of 14 Posts
