I was measuring the length from the center of my crank arm bolt to the top of my saddle to find the correct saddle height, but I ran into a dilema I was not expecting.
Th Ned Overend books states to measure your inseam length with feet shoulder width apart, I wore my shoes,too (I've seen other places to do this). Than I multiplied this measurement by .883 and got my saddle height (or at least a good starting point). (33.25x.883=29.36")
EASY ENOUGH!
Now the problem. I have a WTB Rocket V saddle. Those of you familiar with this saddle will know that this saddle has a high nose and back section, but it slopes down in the center section.
If I measure to the center top section of the saddle, from the crank bolt, the front and rear of the saddle are approximately 1/2" higher than the center (I had a t-square/ruler along the top of the saddle to be able to compare the height of the front and rear of the saddle to the center).
So which measurement do I use to set up the .883 distance?
1)From the crank bolt center to the middle of the saddle.
2) Or from the crank bolt center to the middle of the saddle going up to the ruler/t-square I am using?
THanks much!
EASY ENOUGH!
THanks much!
