1 - 4 of 4 Posts
H E L P
I need a bearing for a Ringle Slamma Jamma Headset (1 1/8").
It is for the bottom cup but I think they are the same (top & bottom).
Your help is much appreciated!
T H A N K S
Discussion Starter · #3 ·
slamma jamma ringle
Thanks Eric,
What I can do is measure the size of the one bearing in the top cup but I can't measure the height (since it is pretty stuck in the cup...)....
Is this standard too (so is there a standard ratio in diameter and height)?
and then: where to get it? ebay? or just any hardware store...? Or do I sound dumb now :blush: ?
does any one have a crappy slamma jamma lying around somewehre from which the bearing is ofcourse not that crappy ;) ?
help is much appreciated !
Neo-Retro Forever
take the bearings to a local bearing supplier. There will be a code on the seal, and they should be able to get you a match.
Look up "bearings" in your local yellow pages or online in your area.
1 - 4 of 4 Posts
