lightly tap the smallest cogs with a plastic hammer if you have one. they're dug into the freehub body a little. use a beater screwdriver handle or something if you don't have a plastic hammer. or use a steel hammer gently.RobPaterson said:
lightly tap the smallest cogs with a plastic hammer if you have one. they're dug into the freehub body a little. use a beater screwdriver handle or something if you don't have a plastic hammer. or use a steel hammer gently.RobPaterson said:I took the lock ring off and the cassette still will not come off. Is there another step with this cassette? It is on a king hub.
Rob
The OP said "I took the lock ring off and the cassette still will not come off." Sounds like he's past that point. The small cogs are just dug into the freehub body most likely.osmarandsara said:someone correct me if i'm wrong but I'm assuming you are using a chain-whip in addition to the cassette remover....
