Hi All, new to this thing so forgive any major posting blunders that may ensue.
I am having noise and vibration coming from my rear wheel that I cannot diagnose.
I thought it was the brakes, maybe the pads vibrating against the rotor, so I (1) replaced the pads, and (2) cleaned the calipers (which were very dirty). I cleaned the calipers/pistons with a tooth brush dipped in DOT 4 brake fluid and used compressed air to remove the excess fluid and grime. The pistons moved freely and retracted. Went for a test ride, just as bad as before the servicing.
Here are the symptoms and details:
1) On a bike stand, the rear spins freely and comes to an even, gradual stop.
2) Running Avid Juicy 5. 3 years old, new pads.
3) Rotor is snug to the hub, shows sings of use, but not overly grooved.
4) the Noise ONLY occurs during coasting, and seems to be independent of speed.
5) Noise persists even when I engage the brake with light pressure.
6) Noise sounds sort of like the honk of a goose.
7) Problem is getting worse & at times feel vibration into my cranks.
8) The center portion of one piston is chipped and no longer flat, the outer surface fine.
9) WHole bike FULLY serviced 9 months ago.
Alright, Doctors, that's about all I can think of.
Appreciate your input very much, and may your next ride be your best ride.
