Properly tensioned spokes (any lacing) do not need threadlocker.b12yan88 said:I heard that when using radial lacinig you need some locttite stuff to keep it from unwinding.
What is a good solution to use with Steel and Brass nipples after you grease it up and trued it
I use Phil's Tenacious Oil.b12yan88 said:Alright, Thanks for the help you guys. So what type of Anti-seize am i suppose to use ?
