1 - 4 of 4 Posts
hi,
does anyone knows what size mount kits do i need for the monarch plus?
my frame is 2014 giant trance 27.5.
i dont know how to measure the bolt diameter(m6 or m8), and if its 12.7 or 12mm eyelet and also the length.
thank you
Biking Like Crazy!
hi,
thank you
Your should be 21.85 mm wide are are standard 13mm (1/2 in.) ID eyelet.
Don't know if they are M6 of M8. If you have the old ones, just measure the ID (or the OD of the mounting hardware.
Discussion Starter · #4 ·
blcman - it looks like my upper and lower mount has different size, you are correct on the 21.85 width on the upper, but the lower part has different width and bolt size, i measured it and the bolt is 1/2 inch and the width is 10mm, but i cant find any of that size being sold, so maybe my measurement was wrong.
has anyone with the giant trance 27.5 replaced their rear shocks? what is the exact measurement for both lower and upper mount?
thank you
1 - 4 of 4 Posts
