i think the trick is called getting a 69er
I fear commitmentbatokstate said:a little more commitment .
...............and bottom bracket drop.mtnbiker72 said:Its the length of the Chain Stays more than anything on the 29ers...longer chain stays combined with a larger diameter wheel.
L O L !iliketoridebikes said:i think the trick is called getting a 69er
Yes it is simply part of the deal. There is no way a Sultan will manual the same way as an RFX. It will require more work, practice and technique on your part to get the front wheel up. Have fun.cutthroat said:Is it just a trade-off for the bigger wheel and the steeper HT geometry (70 degrees)
