1 - 7 of 7 Posts
Today i was changing the semi-bath oil on my Minute Expert 2011, and when tightening the bottom left leg bolt of the lowers, the bolt just kept on turning. I didnt over torque it, i was barely hand tightening it at first and then with a wrench.
I tried tightening the bolt on the silver shaft where it bolts on without the lowers, and the shaft itself was turning, so im not sure if when the lowers are in place, the shaft locks itself somehow, or i stripped the threads on the silver shaft.
Left leg = spring side.
Those are two brilliant answers, didnt think about that, gonna give it a go tomorrow morning :)
BTW, why make some weak aluminum threads instead of solid steel ones? 15 grams less? :(
People buy forks by the numbers, not on how they stand up to regular maintainence. ;)
But if you are careful alloy threads are fine. Just avoid cross threading or over-torquing them.
Discussion Starter · #6 ·
Ok did those two things today, 100 PSI and downward force on the lowers. I indeed could get the bolt more tightly in, not a complete solution but it worked.
What if the next time i change the oil, i put a little o-ring on the top of that shaft, so it has more friction against the lowers, avoiding it from spinning?
Next time you have it apart, check the bolt threads in all the way easily by hand. It's easier to check and clean threads with the fork apart.
1 - 7 of 7 Posts
