It's not oil.
-Chris
http://www.enduroforkseals.com/
It's an injected lube. They may have been using PrepM (but who really knows what they were pumping in there?). Whatever it is, it looks as if it is starting to liquify/break down. You need to separate the uppers and lowers, clean out all the residual lube, re-assemble your fork, and pump a few squirts of lube into each port (you'll need to do this every few rides). By the way, get used to the rings on the stanchions--that's the only way you will know that you are still lubing the bushings (just the way the Microlube system works). Just as an aside, I like using Rock 'n Roll's Super-Slick Grease, but the PrepM is OK, too.Bart said:
-Chris
