I just picked up an 05 Enduro frame and am having trouble getting the front derailleur to work properly. I am using a 2005 XT integrated crankset, with a 22-38-Bashring combo. The bashring is an e.thirteen 40 tooth supercharger.
This setup worked great on my Giant VT, and I was using a 2003 LX front derailleur.
For the Enduro, I bought a 2005 XT derailleur, and the chain rubs on the bottom of the cage when in the smallest gear in front. It does this for all the gears in the back. I installed my old LX derailleur from the Giant and it doesn’t rub in the 3 lowest gears in the back, but it still rubs otherwise. I cannot lower it any more, or else it will rub on the bashring. Again, i did not have this problem with my Giant VT.
When sitting on the bike, the chain still rubs in the higher (smaller) gears.
It seems to me that the derailleur post has a steeper angle than normal, causing the bottom of the cage to be higher than desired. Is there a special front derailleur that Specialized recommends with the Enduro to prevent rubbing on the bottom of the cage?
