Help! Need Cheap Solution!
669 Views 7 Replies 3 Participants Last post by  DcN
When i was oiling my bike i think i must have gotten some oil on the pads of my front disk break(mechanical) because now i have lost alot of stopping power. I don't want to have to pay for new pads and i need a step by step from u guys on how to take apart the breaks to get the pads out if it is possible to fix them for little or no $$$. Help!! :(
1 - 8 of 8 Posts
What brand/model are they??
They came with my bike, the 26-inch Schwinn 240 DSX it says that it is a "Pro Max front disk brake". It says Xnine on the front break, it that helps. And now i have another problem, i am bringing my bike to a bike expo and i put tire polish on the tires, but it got into my breaks, i fixed my back v-break with water and lots of elbo greese, but my front disk still doesn't work.
Please help my guys, this expo also has a trick showoff and i need my front disk up and running! :( help!!
use isopropyl alchohol
try to clean them with acetone or isopropyl alchohol. you can find it in a drugstore
how do i get the pads out?, hurry with responses, the show is this wednesday
Help The Show Is Tonight!
sorry if it's late
just "spray" it. You don;t need to get the pads out. Just the wheel.
Help, gas, sanding roters, r these safe?
one of my friends sujested using emery cloth(sandpaper for metal) on the roter, caz mine looks a lil darker then normal and when ever i run a cloth over it, the cloth comes out black. Another friend sujested using gas to clean the pads and the roter, is this a good idea?
Help guys!
(fyi- i borrowed a friends disk setup for the show, hes got 200mm roters, is was SwEeT)
1 - 8 of 8 Posts
