I have done a few CX bikepacking trips this year - loving it. I am leaving this afternoon on my first MTB overnighter. In setting up my gear, I noticed a consideration I had yet to think about....at full fork compression, my Revelation 130mm arch will absolutely bottom out on my drybag in my Revelate harness.
And looking around, this doesn't seem uncommon. Rockgeist's bag (photo below), is designed to secure the load with straps under the crown. So by default, at full travel, the arch will ram into your straps/dry bag.
On my Revelate harness, I am considering leaving the headtube strap as loose as possible so in the event of a bottom out, my arch can at least pivot my bag up a bit to reduce the slam-factor. But then of course it's bouncing around a bit 99% of the time...
So what's the thinking here? Are you just not using full travel? Anyone else share this concern or am I being worried for nothing?
Cheers.
Cheers.
