Look at a Marzocchi Z2 or Manitou Machette which are both in the same price point. You also may want to check the used market. I scored a slightly used Fox 34 Rhythm for $300 not that long ago.
Sorry, but incorrect. A 20 mm longer fork raises the front about 15mm. Likewise you cannot just increase sag to compensate. All air springs have a curve, increasing sag (all other things being equal) increases the spring rate at sag and will lead to a stiffer ride.You can add up to or subtract 20 mm I f travel on the front fork. If you go up to 140 mm it will only raise the front about 1/4”.
After some exhaustive reading, I am leaning towards the Marzocchi Z2 in 140mm. A couple of questions about it though, I think the additional 20mm will be NBD in part because I ditched my 2.8 tires for the Bonetrager 2.6 which are a lower profile by about 3/8", but what about differing offsets? The Judy Gold is 42mm and the Z2 is 44, is that also NBD?It came with Judy Gold 120mm travel, do you think the Yari 150 would be too much of a change in head tube angle? You are correct in that i have an XL frame it's a 68* head tube angle, I run Bontrager 2.6 tires.
Please see above, so you would not recommend this and I should stick with the 120mm travel?Sorry, but incorrect. A 20 mm longer fork raises the front about 15mm. Likewise you cannot just increase sag to compensate. All air springs have a curve, increasing sag (all other things being equal) increases the spring rate at sag and will lead to a stiffer ride.
I would. The longer fork will slacken the seat tube, shorten reach, raise the bars, and raise the bottom bracket. That frame already has short chainstays relative to the bottom bracket. If you want the steering more relaxed, use an angleset.Please see above, so you would not recommend this and I should stick with the 120mm travel?
Nobody can feel 2mm of change in fork offset, most don’t notice any change from 51 to 44 offsets.Thanks man, I am definitely a greenhorn when it comes to the modern geometries.
That Z2 comes in 120mm so I'm set with that, will I notice the 2mm offset difference?
